TwistedTy
More boost! N.A.S.T.E
im almost done installing a 60-1 turbo downpipe and cat. now on the stock turbo there is a hose that plugged into the intake side of the turbo into what i beleive is the actuator. Now the turbo im using now does not have that hookup so im guessing you would have to plug that hose off and run base boost. is this correct? There are 2 hoses coming out of the actuator.one on top and one on bottom. do i plug the hose that went into the stock unit, then use the other hose to connect to the wastegate?
