Wastegate shudder?
the baPhoon
Ive been chasing a wierd noise for a while now. It only happens around the time boost is initiated, between -1 and +2 on my gauge i get a little fluttering sound (when going from vac to boost or holding at a low boost range < 3 pounds) comming from the turbo area.
I had a mechanic tell me it was knock, but i really doubt it. As it sits my turbo will peak at around 10 pounds and it has an issue holding boost. Im wondering if my wastegate flapper could be shuttering at around that boost pressure range and causing the sound. I got home from a long drive lasltnight and had a talk with a buddy who suggested a wastegate issue, which is why im posting this.
All the vac lines are new and i have a new boost controll solenoid with under 1k miles on it.
Im gona go get a DM run later this afternoon and post the results.
At first i thought the noise may have been the impeller contacting the houseing, but i pulled the intake tube and checked the blades and play of the impeller and there is nothing out of the ordinary.
As i said, if i maintain boost around the 2 pound range the sound is intermittent, but if i boost over 5 PSI the sound completely dissappears. Anyone have any similar WG issues or am i going in the total wrong direction?
WyoSyclone
Re: Wastegate shudder?
Hate to say it, but that's exactly what mine sounded like....stock, old turbo was going bad with a bit too much play - not a lot, but just enough to cause a strange shuttering sound....sounded like a low, growling kind of knock. I switched to the Stage1 and it sounded like an entirely different motor.
the baPhoon
Mine kinda sounds like 3 small pebbles being shaken in an empty pop can.. If its the same ill jake yank it off and send it to waller hehe
another 600 bones down the drain
