Wastegate Solenoid
sy605
I have a dumb noob question. I did look and didn't find anything. (even did a google search)
On the solenoid on the wastegate side there are two ports. The one on top is running to my wastegate. The lower one (which has a metal hose clip) has nothing connected to it. Should this be plugged or does it connect somewhere else?
Im stealing TNPHOON'S pic for reference.
aasltmike
Re: Wastegate Solenoid
Nothing gets connected to that and it should stay unplugged. No explanation to offer, but I had the same question after I bought my Ty and that's what I was told. :tup:
sy605
Thanks! Maybe vault this for noobies??
matice00
X2 on vault. I thought something was missing, and searched every vacuum diag pic, till I stumbled on a post where someone talked about it.
13Pelle
My solenoid had a small square piece of foam on the nipple between the metal pieces when I got my truck. I don't know if it was factory but it looked like it was. FWIW
aasltmike
If no one has one up by tomorrow, I can put a pic up of mine so it can be vaulted.
wildphil
I Love My Ty's
Yes that port needs to be left with nothing connected to it.
They did come with that foam piece on them. I think is like a filter. But they fall off very easily. And everyone leave them that way.
The open port (originally had a foam filter on it) is a "vent". The solenoid works by putting pressure into the Wastegate canister through the solenoid, grabbing that pressure from the compressor housing. To open the WG to control boost it then "quickly" releases that pressure. Pressure has to go somewhere hence why it vents. If you hook up the vacuum lines to the wrong ports the system will NOT work correctly.
sy605
So don't worry about it? Do I need the foam filter or just leave it be? Are the little filters still available?
13Pelle
I haven't found the foam filter on its own as of yet. I know they come (or at least did) on the Waste Gate Solenoid when you bought them new. I would leave it on if for no other reason, it helps keep dirt out of the solenoid ensuring proper function. If it is already off, I don't know if I would worry about spending $40-90 on a new solenoid just for the filter. :2cents:
