water/alky mounting????
sy112
I was wanting to get some opinions on various mounting locations of the water/alky kits. I know of the common one, on the intercooler. I thought I have read about another place to mount, but can't seem to find it in the search. Seems like someone mounted it after the turbo but before the intercooler for better atomization but wasn't sure if it was worth it cause of loss of cooling power. Like I said, read it a while back and forgot to save, so it is kind of fuzzy. Anyway any input of where you guys mounted and how you like it there and if you would have liked to have mounted elsewhere would be appreciated.
leroy
Don,
I've installed 2 systems and installed the jets on the throttle body side of the intercooler. If you use an Aquamist system, you don't need to worry about atomization.
If you have EGR disabled, you could use the EGR ports in the upper intake. You may have to hog the ports out a little to make it work well. If I do another one, I plan on trying the EGR ports.
Jim
sy112
That sounds like a good idea leroy, anyone else usng or heard of this. Even if on the GN's or another vehicle. I will be using the SMC kit, if it ever gets done. Seems like everytime you order something it majically gets backlogged for a month :x I think the SMC has good atomization, but not real sure. Was just trying to get some people brainstorming, never have been one to just do what everybody else has been doing. Hell, if we don't always try to improve, we might as well be driving Lightnings :lol: (flame suit on)
spooldup
Super Member
not sure if maybe you read something i posted? I have my zex fogger before my ic to cool the ic down plus the benny of nos. I have my aquamist jet in the upper ic throat right in the center on top. It's too bad we can't use "nos" brand tb's. They have a fogger built right into them!
Sy769
Daron tried it before the intercooler and I believe he moved it back to after the intercooler. He'll prolly chime in.
There has been some discussion on water/alky condensing in the intercooler.
I wonder about the distribution with using the EGR port vs. the TB.
Wouldn't be hard to put a jet in the EGR port and give it a shot.
leroy
Next time you have the throttle body off, look at the EGR ports just inside. There are two, in line with the throttle body bores. I think distribution would be fine. After all, GM wanted exhaust gases recirculated evenly.
Jim
sy112
sounds like it is at least worth a shot, figure I'll be the guinea pig on this one, IF it ever comes in!!!!!! :x
