George Blake
DONATING MEMBER
This started here:
http://www.syty.net/forums/showthread.php?t=50299
But seems better suited in the body forum.
I ran a garden hose on the firewall.
Water came in as a trickle on the inside in 4 places.
Trickle from the edge of the fuse box.
Trickle from a line coming through the firewall up by the brake pedal fulcrum.
Pours in from the "baffle" for the brake where the rod goes through the firewall. There is a "baffled" accordian style boot that looks like a boot on a rack and pinion steering system. Water comes in right at the bottom where it goes through the firewall.
Trickles in through where the wire harness comes in through the firewall.
Some things. The seal that goes acrosse the lip that the hood is supposed to ride against is gone and both hood hinge seals are gone.
What I'm wondering is, rather than attacking these leaks individually, maybe these missing seals are allowing the water to run down the firewall where it not supposed to be? When we get really hard rains and when going down the highway at 65 mph in hard rain, it comes in. Am I on the right track thinking the missing seals and maybe checking the drain holes are more of a concern?
