Water jacket hole in block ?
Lynn D. Brown
Guys,
I'm adding water to start up and it starts leaking out what appears to be a threaded hole on the Pass side of the block (Bowtie) towards the front behind the ATR exhaust manifold flange. With the stock Exh. Man, it looks like hole would be exposed and maybe U could screw a plug in, since they do not have a flange straight across to block the hole - like the ATR's do.
Does anyone know what this hole is for ? It looks like I will have to pull off the exhaust manifold on that side, which means that I will probably have to remove the Downpipe, CatCon to get them out of the way, then the Turbo also. So much for getting it running in the next 2 days so that I can drive it to start my new job ~ 1700 miles away. Always something !!
Lynn D. Brown
Correction - that threaded hole is in the Pass side HEAD, and I have the late Vortecs. Not sure what a threaded hole would be there for ?
But I guess I'll have to plug it - and with a plug that will fit flush, so it doesn't interfere with the header flange. Not sure whether the stock heads have this hole or not ? Maybe I could cut a piece out of the header flange - however it's stainless, so that may not be easy.
smeagol
Just plug it, you can find plugs at hardware store or use AN one that would be flush (allen bolt style). If you notice, the pass/driver's side heads are the same - that hole is used on the driver's side (on every app I know of at least) for a coolant sensor. They use 2 on the SYty's, one in head, one in the intake -- - one goes to the gauge on dash, other goes to ECM.
It should be either 3/8 or 1/2" NPT (3/8" sounds correcter)
Lynn D. Brown
I think the SyTy Coolant sensor (the gauge one) screws in to the BLOCK, below the headers, on the drivers side. These holes are only about 1" down from the top of the HEAD and ~ 5" in from one end.
Not sure what they were used for on other cars.
Lynn D. Brown
Water Jacket hole
Water Jacket hole
I screwed the Coolant sensor into the block hole and it fit. I guess that's probably where the Turbo oil supply was from. So, now I guess I'll have an oil temp sensor instead of a water temp. one.
smeagol
Re: Water Jacket hole
Oil supply is dinky and is near oil filter relocation stuff. You prolly stuffed it into the coolant line used for the stock turbo stuff.
