Water/Meth Injection Installation
Michael
I am now the proud owner of an Aquamist Stage 1 system from Ivanko Barbell. Where is the best place to install the nozzles?
It looks like the system does not come with a tank. Any suggestions for a tank which will fit in a Typhoon with an ATR cold air & battery relocation kit?
Thanks,
Michael Pliska
Flyin Ryan
hated cuz he drives fords
Michael
Re: Water/Meth Injection Installation
Thanks! Duh, I hadn't thought of the fact that the windshield washer reservoir can still function for its original purpose, since I'll be using washer fluid for injection anyway. I don't drive my Typhoon hard enough to need it very often, but I definitely need it for dragstrip passes.
Thanks,
Michael Pliska
jpalmer
is there any tanks that dont look like crap plastic like plastic lined aluminum or something better looking
Flyin Ryan
Ralph viciousv6 is running a custom fab'd aluminum tank I believe but as far as off the shelf I don't think there are any.
Also Canton makes some nice aluminum tanks for mustang ic systems that you might be able to use.. but Im not too sure about holding meth in aluminum.. i'd research it before doing it
Michael
My company (ISSPRO) makes (amongst other things) fuel level sensors for military and heavy truck applications. IIRC, methanol in aluminum is only acceptable if the aluminum is anodized. I'll check with my materials guy on Monday.
Regards,
Michael Pliska
