lightspeed240
truck it!
Hey guys, Im hoping someone can give me a recommendaion on water pump sealing. About a month ago, my waterpump was able to pull itself loose from the block on one side, causing a huge leak. Come to find out, the radiator fan was loose also, so I can only presume that the wobbling of the fan was enough to torque the waterpump loose. I went ahead and replaced the pump with a new factory unit. I used the new, paper-material gaskets, as well as a small bead of form-a-gasket gray on each side, when I replaced the pump. I also used thread locker.
Well, today, the same thing happened with the pump, only the fan wasnt loose. Needless to say, this has the potential for getting rediculous very quickly.
I am thinking that now may be a good time to do an electric fan, since the stock one could be causing or increasing the problem.
So, I had a few questions. Keep in mind that I just recently got the truck and havent had much time to get acquainted with it yet:
1. What is a tried-and true gasket material and process to use in mounting the WP to the block? Ive never had this issue on other cars, using this process.
2. Has anyone else had this problem, and have any idea what caused it?
3. If I go to electric fans, is this going to strain my stock alternator to the point it needs upgraded?
Thanks in advance for the help here.
