The aquamist guys insist straight water is the best. It provides the best heat absorption. They do suggest alcohol mix or windshield washer fluid for below freezing applications.
The Buick guys have had good luck with an alcohol/water blend. They have a lot of experience with it and we have similar setups. You may want to read some of their archives or discussions. The alcohol may help if you're needing a little more fuel.
Personally, I've tried different ratios of water and isopropyl alcohol and have never noticed a significant difference.
Jim
