Ok, hooked the wideband up last night and made a few passes with the WI, the water didn't affect my afr at all, of course it doesn't burn, anyhow it did lower mat's a lot. WI looks like a bolt on kit, no tuning need other than making sure it doesn't bog (simple).
Then I tested alky and found it lower mat temps almost as well as water, but my AFR went from 12.3 @ wot to 10.8, so now I understand the real gain with alky, you have to REPLACE fuel with alky, it's basically like turning on octane boost at high boost, the more 92 you can pull out and replace with alky the more boost you can run. From what I've seen alky is not a bolt on kit, lots of turning needed.
So this leads me to a question, could we inject nitro? (I know nothing about the stuff) except I'm assuming it burns even cooler than alcohol, any ideas?
Mark L
Mark L
