WB 02 start up problems (fixed)
scotts4
ADDICTED
Ok i am running with a romulator for some time with datamaster. I got my plx 300 wide band .
I hooked it up today and the truck lookes like it is runnig in limp home mode VERY rich check engine light is on will not idle and data master will not work it is not finding the ecm.
Here is how the wide band is hooked up
red 12v+ to ecm a6
black gnd to ecm d1
white wideband output to ecm f14
gray narrowband output to ecm e14
I took the conector out of e9 because the egr is dissabled
I got a new bin from Nolan with digs patch
I loaded it whith no problem just like i did a bunch of times before.the green light is on on the romulator.
the truck was sitting for a few weeks with the batt not in the truck could the battery in the romulator be dead ? I loaded a old bin and the same thing happened. I did not take the romulator out of the ecm when i did the wiring .
I am going to take the wb out tommarow and see what happens .
all the wir conections were sodered in and the wb 02 works fine
any one have any ideas what i did wrong
thanks for the help
scotts4
ADDICTED
I went over all my wiring and it was good . then i went into my house and redownloaded the new bin put it in and all is good .The first bin must of ben no good for some reason thanks anyway
