Long story but my WB readings are not showing up on DataMaster. It's as if I'm getting the narrow band readings. Anyway, I've got the ECM out, gonna double check everything. What I'm asking is, as a check to the info I have, where does the WB connect to the ECM. IOW which pins should I be connected to. WB is a PLX and I'm using both the stock o2 and the PLX.
It could be as simple as I've connected the wrong pair from the PLX but I want to be sure.
Thanks
Thanks
