WB error and Tach flutter when alky sprays
TYTILIDIE
METH HEAD
When I go WOT, I get a bunch of tach flutter, oddly enough not a whole lot of knock follows it. I turned the pump off and went back to my other bin and it doesn't flutter at all. Did a tune up just in case. Now, also at WOT, sometimes the WB (LC-1) comes up with a E9, which I believe is a low voltage error. Any thoughts on what might be happening here?
J-bird
Re: WB error and Tach flutter when alky sprays
Mine did the same thing. I installed at capacitor between the hot and the ground and it went away. I don't remember what uf the cap was but i found it by searching on the board here.
denny
Maybe you are spraying too much alky at low boost, try turning it down.
Flyin Ryan
hated cuz he drives fords
how's your volts?? where do you have the power for the wb unit ran tied in??
TYTILIDIE
METH HEAD
Haven't done an actual voltage check but, I have it going to one of the IGN ports in the fuse box. There are only two from what I can see. They are switched. You know what though, I had a thought, after I posted this of course. I HAD my electric fan for my trans cooler plugged in to one of those and when I would turn off the truck and that fan was on, and the lights were on you would hear the door ringer all choppy until the fan stopped turning. So maybe I should find another power source.
Loeryder
tach bounce = electrical noise.
The cap will filter that out.
I had tach bounce when it was wired into the fuse box.
once i put it on its own circuit it went away with no cap needed.
remember you are sourcing an entire 2nd fuel pump so its gonna take some current especially at turn on point.
Daron
What Jas says. I did a write up on here years ago about my experience with this issue. I recall that I could get Knock retard on my scan tool, with the ignition on, data logger runnin, but engine off, when I engaged my alky pump. Sometimes my tach would even jump around, with the engine off, and energizing the pump. With the engine running Id get both tach flutter and knock retard. I first tried a capacitor, which worked. Later I rewired the power for the alky...
TYTILIDIE
METH HEAD
Should I use straight power from the junction and send it to a relay?
Flyin Ryan
What junction are you referring to? if you mean the factory one up on the firewall i'd say no if it's still the stock 14 gauge wiring considering the fact that it's 14 gauge wiring at best which most likely was built to handle only 15-20 amps I wouldn't risk it.
TYTILIDIE
METH HEAD
Yeah I was reffering to the junction on the firewall over the trans dipstick.How about straight from the battery to the relay? Or am i being to ridiculous and just need to find a different place under the dash?
Does it need switched ignition power? If it doesn't, you could alway put in an inline fuse run it to the junction, fuse block or battery.
denny
When I spray too much meth, I get tach and engine flutter/sputter, this cause the ecu to see knock.
If the electrical thing dosen't work, try turning down the alky. (full at 15psi or use a smaller nozzle)
Denny
