I JUST BOUGHT MY FIRST TY 2 WEEKS AGO. SHE WAS RUNNING REALLY RICH WITH FUEL PRESSURE READINGS @ 55PSI. IT WAS HARD TO START AND TO KEEP RUNNING. I FOUND THAT THE TY HAD AN ADJ FUEL PRESSURE REG AND WAS UNABLE TO TURN THE ADJ NUT. SO I PUT THE STOCK REGULATOR BACK ON AND IT STARTS FINE AND SEEMS TO RUN BETTER. MY QUESTION IS THERE IS A SLIGHT MISS I CAN HERE @ IDLE. ALSO I CANT READ MY BOOT LEVELS (BOOST GAUGE ON ORDER) BUT MY BOOST SEEMS REALY INCONSISTANT AND DOSENT PULL VERY HARD. I AM GOING TO ORDER DATAMASTER TO HELP WITH DIAGNOSIS AND TUNING. ALSO THE TRANS SEEMS TO SHIFT EARLY INTO 3RD AND 4TH GEARS. ANY HELP WOULD BE GREATLY APPRETIATED.!!!!!
