Weird turnsignal problem just started
2500avalanche
Well-known member
So. This just started to occur today. With my headlight as well as parking lights off, all of the turn signals work. Whe n I tur n the lights on, the drivers side works, but pass side doesn't signal inside the truck or outside. Any hints?
jimmyz79
Re-Member
Re: Weird turnsignal problem just started
JMHO, sounds like a loose/disconnected ground wire. Directional was grounding through headlights/parklights when they were off.
Mingus
Check your front and rear turn signal bulbs on the passenger side and the grounds for them. Try wiggling the bulbs while you have the lights on and turn signals going.
