Weld Draglite XP Wheels/Tires
A few have asked what my wheels and tires weigh, so here we go.
I bought Jack Ostrander's Syclone 2730 with this setup. I don't know if it is optimal as he did not have very good 60's and I have never raced it.
The fronts are 16"x8.5" Weld Draglite XP w/5.5" backspacing. They have 255/50 R16 BFG Drag Radials with about 35psi of air. They weigh 45.5 pounds.
The rears are 16"x8" Weld Draglite XP w/ 4.5" backspacing. They have 26x10.50-16LT MickeyThompson ET Streets with about 17psi of air. They weigh 43.0 pounds.
Both were weighed with a fairly accurate scale designed to measure freon as you service a car or house A/C system. It can measure Kilo/Gram to the tenth and Pound/Ounce to the tenth.
The next question is what are the heights/circumference of the tires installed. Well, according to Jegs/Summit the BFGs are supposed to be 26.1 and the ETStreets are 25.9. I don't know what width wheel that was on.
The BFGs are about 25.5" tall with 81.75" circumference.
The ETStreets are about 26.5" tall with 82.75" circumference.
I was originally concerned that the ETStreets were going to be too short, but I was wrong. That extra half inch of width on the fronts really pulls down the height on the Drag Radials. Would I recommend this setup to others? Maybe not, I would look for identical widths and the same tires all around for a perfect drag race setup. But I really can't say as I haven't truly tested this combo. You can find pics on my Yahoo photo album, just cut and paste into your web browser.
http://f1.pg.photos.yahoo.com/ph/cad78/lst?.dir=/Sy2730
Hope this helps, Christian
10secTy
Sy-Ty builder and Tuner
Thanks for the info. I put my front ZR1 with 275/40/17 drag radial on the scale and it was 51 pounds.
I have not weight the rear yet.
Stock front was 46lbs.
So I could save about 5 pounds each front wheel and more on the rear.
Now I need to decide if it worth the money to change over for 20-30 pounds.
I like the looks of the ZR1's and I guess I could just turn up the boost up some more
:lol:
Nolan
