Well Crap... pilot bushing and AFPR
Got my freshened up used motor and tranny started the other day. Got the ECM down and have ostrich + WB + ALDL finally working. But then I heard a rattling noise coming from the back of the motor. Sounded like a lose bolt into the torque converter or something hitting the teeth on the flexplate. Got under the truck and everything looked good. Went to pull it in and in D and R the noise goes away so that means the noise is coming from slop between the transmission input shaft and the crank, correct?
Damn. I don't want to pull the tranny. But it is my fault. I made sure everything was clean but didn't check the clearances. Will it hurt anything to let it go for a while? It does make my knock counts go to the moon in datamaster.
Also, I think the diaphragam in my AFPR is bad. It had been sitting around for about 5 years unused. When I start the truck with anyone's 60 lb injector tune it is WAY rich. WBO2 pegged at 9.0:1 which is the max on it. It will even out to 10:1 at best when the target is 14.7:1. I did smell a little bit of fuel when I pulled the vacuum hose off, but it wasn't excessive. I lowered the values in F28 and had to go below stock values to get a 12:1 AFR and then it started oscillating pretty wildley between 11:1 and 18:1. Oh, fuel pressure was ~42 PSI.
