well finally started tuning for power
turbotater
i have been working on my drivability issues and i am
finally at least in the ball park . so last night i tried
some low boost runs and i ran out of fuel injector
earlier than i thought i would. at about 8 lbs of boost
i am ok with about 95% duty cycle , it feels like my
old turbo with the 20 g wheel at about 17lbs or so .
these are still the stock injectors @ 43 psi base .
so the question becomes do i buy a set of 50 or 60 pph
injectors or modify the ecm for some 72pph low z's ?
any thoughts ?
mike
VermontTy
Support Our Troops
Re: well finally started tuning for power
No doubt you ran out of injector....start pushing much more than stock, and you'll run out quick. Did I hear you nabbed 75's?
turbotater
yea i went to some 75 lber's . i used the typical hot rod
logic that if i am running out of injector with a 58 mm turbo
what i really need to do is to put my 70 mm turbo on .
i got me a cermaic coated .81 housing a couple of days ago
and i picked up some metal today to fab some v band flanges
so hopefully i can start it up this week or next with the new stuff .
that is if i can figure out the way to modify the program to work
with the big injectors . the ecm i think will be no problem .
anyone want to help the kid on the "short bus" with a starter
program ?
mike
