were do I find this??
Bill Z
Re: were do I find this??
sy1219 said:
need to update to A newer program. do you know were (Trxtd200.dll) is in the C:/ command?
Thanks!
Aj.
I don't have it on my machine. I suggest you do a search on your box. Right click on the start button, then select search. Put in the DLL name and make sure you change the 'Look In' box to 'My Computer'. It should tell you all of the occurrences of your DLL.
Good luck.
Flyin Ryan
hated cuz he drives fords
After you installed the TT 3.4.1 datamaster softwere... copy your Trxtd200.dll file into the c:\windows\system32 folder.. overwrite the one that's in there already.
It will still display errors that your software isn't registered, however it will let you continue to record past the 20 limit mark.
anyways how come you didn't just copy the exe crack file into your dm directory and launch it?
