Aeroking
e.i.
On a stock turbo... If you lengthen the actuator rod all the way out (least boost). Is the wastegate closed under no boost??
I noticed that with the rod shortened (more boost). The more i shorten the rod, the quicker it spools.
So my question is, with the WG rod set to 14~15psi, is the WG closed with pressure holding it shut, or is it slightly open (causing a slower spool) ??
