WGDC and psi to enable closed loop
sae
What kind of values are you guys running? I'm having to run ~95% to hold 14-15psi with it going CL at 11psi. I saw that the ATR chip goes CL right away with the wgdc sitting at 75% without adjustment and makes 15psi, if I do that I probably won't even make 10psi.
sae
Re: WGDC and psi to enable closed loop
Well this is probably part of the problem, hole on wg rod is about even with pin.. Are you guys going 7/8 or 1/2 hole? Am I able to go shorter being that I can readily adjust the wgdc?
sae
Well I went with a hair under 1/2 a hole just to see for myself. Going closed loop at 10psi with wgdc dropping to 70%, I peak at 210kpa and level out around 195 ±10, huge difference and a lot of wiggle room for changing duty cycle in bigger increments than I was being at 95%. Going to mess around a bit more with it tonight and try to get any spikes ironed out but so far it holds pretty steady.
