What a difference
T-Bone
Hey guys, the install is complete on the A2A system I fabricated for the Lap 1 Ty. After blowing off a pipe at +1 PSI while testing, I removed the entire system to have a local fabrication shop weld beads around the ends of the piping.
Reinstalled the system yesterday afternoon and took her out again. This thing is incredible and the power increase with alot lower IA and exhaust temps is astounding. Truck felt like it was on the very edge of coming unglued from the surface of the road between 20-80 MPH. The current K/N filter versus the nasty paper air filter that was slung down near the front of the truck must have enhanced the airflow as well. Can't wait for the Shindig event.....
Pre-install temps:
IA: 125-130 and jumping to 185 after a 8 second full boost run (19 PSI). Took at least 3-5 minutes at highway speed to come back down to around 140's range.
Exhaust temps: 1450 average
Post install temps:
IA: 71-74 and rising to 76 after a 10 second full boost run (23 PSI). Takes less than a minute to be back down to pre-boost temps.
Exhaust temps: 1250 average
I have NO idea why Scott did not do this over his meth/H2O injection system to begin with but I am about to convert all my stuff to A2A with a large IC. Will attach pics of the finished job after while along with a cost breakdown for other members that might consider doing it themselves. For now, I am pumped!!!!!!!
T-Bone
Re: What a difference
Pre-install temps:
Post install temps:
Pics as promised :).
T-Bone
What IC did you have installed in the before?
It didn't have one at all. The turbo was piped directly into the intake and under boost, my IA temps were spiking drastically (easy to see why). The progressive water/methanol system on the truck works at partial boost levels but I don't run around at partial boost ;). I still wanna build an air box around the K/N filter and install some fog lights but for now, it is spot on where it needs to be.
Brassmonkey
Cruzin' Mel Man
Building an air box will help a lot with IA's also. What kind of throttle body do you have?
2kwik4u
Resident slow guy
Why didn't it run at full boost?
T-Bone
So it was operational, just not enough. Interesting. I've seen others run similar setups (water/meth only) with good results.
Mike, it ran fine but I could only lay into it for about 10 seconds at a time. Then I would have to wait a good bit for it to cool down. I am thinking the meth pump is not working to full capacity though because you are right....it should have rendered better results. I am super, super happy with the current performance though.
T-Bone
What I meant to say is that the water/meth works fine at 1/2 boost but is inadequate at full boost to render the cooling required. It works at full boost but it wasn't enough.
2kwik4u
Resident slow guy
Yea, I gotcha now. I was just confused. I've not seen results like that in the past though with other trucks running similar setups. Hardmans truck never ran quite right to get good results with his setup, Jeremy's truck tried it for awhile, but the gains over stock didn't warrant the change. I think Daron ran with that setup for a good long time though with good results.
You obviously have the data to back it up, so there's no question the new system works better. Just surprising to see the previous setup not work so great.
Do you have any pictures of how the tube runs across the engine bay from the drivers side fender well? The engine shot shows the return from the IC to the TB, but nothing from the turbo to the IC.
T-Bone
No but I can snap one for you. My concept was a bit different as I piped the air under the front side of the truck rather than across the engine bay. One pic shows the piping descending through the PS wheel well area and the next shows it ascending through the DS wheel well where it enters the IC. It exits the IC on the PS and is almost a direct shot into the intake. My reasoning is that heat rises and the air passing through the IC and then immediately through the radiator would be hotter than ambient temp and therefore keep the crossover tube hot, resulting in hotter intake temps. I was hopeful the air down low over the aluminum pipe crossing the forced air over would serve to render further cooling. Not sure if my reasoning was profitable but at least it made some horse sense to this country bumpkin :).
2kwik4u
Resident slow guy
........ I was hopeful the air down low over the aluminum pipe crossing the forced air over would serve to render further cooling.........
This is the concept that the guys at STS turbo (the remote mount systems) use. While it does hold some water in terms of engineering, a full intercooler is best in all conditions. The overall surface area between the air and the substrate (in this case aluminum tubing) is what causes the cooling. More is better. You certainly didn't hurt anything that way.
Thanks for the info!
qbnkiller
Conflaguration Specialist
How big is the IC core (and how thick is it)? What size turbo are you running? Looks nice though!
