Re: what are the best plugs
What makes the iridiums better? Longer life? Better idle? Just curious...
According to NGK and Autolite, iridium has a much higher melting point than copper, or even platinum which means they will last longer. The fine wire electrode supposably also requires less voltage to fire so they claim more "consistent & stable" spark. Basically what I have seen is they do last longer, and can better stand up to higher output ignition systems.
On a side note, when comparing sparkplug metals from a conductivity standpoint, copper is the best, platinum is the worst, and iridium falls in between.
