What constitutes an alignment?
syntax
Does unbolting one balljoint and backing out the axel an inch constitute an alignment after all is said and done? I just need to get to one of my brake conversion bracket bolts that the axel is blocking from coming out
jpalmer
Re: What constitutes an alignment?
it should not, unless the balljoint is replaced with a different one. I have done this with other trucks and not had a problem. but if anything is worn out then it will prob move, needing an alighnment
