What does a code 35 iac error mean? How do i fix it?
jwaller
Evil Genius/SyTy Guru
usually this means the IAC motor (loacted on the underside of the TB) has gone out. has your truck had a bad idle. quit while idleing?....quit when you turn the AC on? if not reset the ECM and see if it reappears
Daron
Not really a topic for the Lounge. A perfect candidate for the "How To Mod and Repair" section though...
<font size=-1>[ This Message was edited by: Daron on 2002-04-01 09:33 ]</font>
spooldup
Super Member
actually it has stalled out on me for no reason. I will reset the computer like yoiu said to do.
mmp142965
say it like you spell it!
Re: What does a code 35 iac error mean? How do i fix it?
spooldup, did that fix the problem? I have the same error, even after I replaced the IAC. Thanks!
Often IAC problems are due to clogged up IAC passages. If it has higher miles (100K+), take out TB and clean out the passages under the bottom plate of the TB, you will need new gaskets as well.
mmp142965
Thanks Dave, I will try that.:tup:
SyTyJedi
Jedi Council
I have cleaned my IAC and the entire throttle body several times. It would work better for awhile, but issues would return eventually. I finally replaced the IAC and never thought about it again.
mmp142965
well this would be the second new IAC, hopefully after I clean the TB everything is good. I have a TB gasket kit on hold so maybe I can do it tonight. I sprayed TB cleaner into the throttle body and that is when I started having problems with the IAC. Thanks for the help guys!
