what else do i need?
TwistedTy
More boost! N.A.S.T.E
just ordered a pte52 kit from RPM. The build on my engine is as follows, speedpro pistons, eagle rods, .30 over block, ultimate, FPR, walbro 255. Will i need injectors for this combo? also what estimated hp and 1/4 times would ya think with this setup? The trans was also done with the dynotech hipro-build. with a 3000stall 10.5 converter
Stangbeater
How bout it?
Re: what else do i need?
50 lb injectors atleast.
Vortec heads
bigger cam
high volume oil pump
timing chain set
Gasket set
bearings
roller rockers
push rods
roller lifters
new vacume lines
Alum H2o pump
mini starter with heat wrap
ceramic coated manifolds out side only
3 bar map sensor
I would talk to Hood or Lee or Waller. They will be able to give you great list of parts.
There are lots of things I missed. Might try a search also.
mattw
Vortec heads
bigger cam
timing chain set
Gasket set
bearings
roller rockers
push rods
roller lifters
new vacume lines
Alum H2o pump
3 bar map sensor
I wouldn't say he needs any of that stuff... You could def max out the stock injectors with your build but they would be about the only thing I would upgrade... If your not planning on running a lot of boost you will probably be fine with them.. .What are you goals? How fast do you want to be?
-Matt
TwistedTy
-Matt
Well im not looking to make it a super truck of any sort i would be more then happy with any kind of 12 second time slip coming out of it. the intercooler is next to be upgraded. how much psi would you recommend running with the setup i have? Thanks for the help in advance
