So I installed Razor's alky kit last weekend, but I am wondering do I need to change the fuel pressure? I am running stock boost with a 20g 8cm turbo, stock chip and injectors, stock Torque Converter if that helps. Thanks in advance.
I've heard of people pulling fuel when the alky turns on... I have 50lbs and Aquamist and I turned my fp down via the AFPR, I can't remember what I turned it down to though. Been so long.
Hopefully you have Diacom/Datamaster to watch your 02's.
If you drop fuel pressure Your doing so across the board... hence derivability issues. So 50lbs might be good for cruising but not W.O.T.
I would suggest getting you feet wet in chip tuning .
