What Have I Done?
TYTILIDIE
METH HEAD
Re: What Have I Done?
Dig, I will definitely look in to that. Seems like that could work out well. I assume the "extension cord" would just stay where it is? So i could change the o2 out without going through the firewall? If that is the case, that will be the way i go for sure.
TYTILIDIE
METH HEAD
Had a buddy over earlier and was showing my fabulous wiring job I did on my truck so far. At this I basically have everything hooked up except for the part of the harness that goes to the front of the truck. So I go to show him these sweet connectors I made to go through the firewall and we couldn't see it. I went to turn the dome light on for the floor light and the friggin fuel pump started running:oops: I was so embarrassed I didn't know what to do with myself. The other day I turned this same switch on and nothing anywhere near that happened. As far as I knew to this point everything worked like it was supposed to. All I could think of was damn DaveP was right, I shouldn't have done this:lol: So anyway, then I turn the key on (I think) and heard sparking. It turns out to be the coil wires. I was like OMG I cant believe this shit!!!! So we pull out the voltmeter and everything is really checking out. I notice the ECM ground hanging off the front of the motor and had a flash back to a few years ago when the ECM wasn't grounded while I was installing gauges and all kinds of weird things started happening. Luckily, we hooked it up and everything worked perfectly to a T. I was happier than a pig in shit. Guess I did it right even with out the manual.:tup:
