What have I got for injectors?
VermontTy
Support Our Troops
These are the injectors that came from my Ty. They were in one of the hundred or so Ziplock bags of parts in the back :eek: . Judging from the pic, and the numbers on that side of the injector, can you tell me if these are stock; 07112 and 0702. (I assume they are...) There is another number, 621020 on the another side of the injector. Thanks.
jwaller
Evil Genius/SyTy Guru
they are not stock as stocker have a red top. they look like the lucas 33's or something close to that. maybe mike or E or somebody else will know exactly what they are. but def not stock.
VermontTy
Support Our Troops
Hmmmmm...
Thanks John. Is there any way to narrow down a manufacturer based on the numbers? There are no stampings or engravings, like GM anywhere, but do the numbers correspond with anyone elses numbering schemes, like Delphi, etc.? Hopefully someone else will be able to shed some light on this.
smeagol
http://www.racetronix.com/621020.html
Part Number Delphi D17208A (Lucas old 5207009, Lucas New 621020)
Static Flow Rate @ 43.5PSI (300kPa) = 31.6 lb/hr = 332cc = 239g/m
Lucas replacements for stock injector. Should be able to swap those in place of stockers with no calibration problems.
VermontTy
Support Our Troops
Thanks for the research smeagol. I've already shipped Waller a set of 50# Delphi's from RPM; These were in a baggie in the back end with the rest of the engine when I got the Ty, and the owner had no clue what they were (didn't even know what a Typhoon was). Enough to make a grown man cry. :cry:
