0966Sy
Code what?
I have a build-up for the Sy and would like to get the fuel system planned out for my goals (low 11's). Right now im sporting the 50# Ultimate with the Razor meth injection. On the stock motor the injector duty cycle was 70% on 18psi with 42 base FP with a 255 pump. Never realy got much 20psi runs in becuase tranny problems :x
Anyway my build up is pretty simple i guess, pretty common here on the BB. I would like to run as much boost as the 50's will allow, preferably 20psi. Also, what fuel pump(s) would handle this build?
Stock block .030, 4 bolt billet caps, ARP studs
Fully ported vortecs 2.02, 1.6, ARP studs, Intakes port matched
Nitrided stock crank
412 cam
SRP .030 pistons
Eagle rods
McCoy A2A
GT35R
RPM DP w/ minigate
ATR Headers
Fully built 700R4 2800 TC
JS coil over's front/rear
Dual In-tank Walboro 255's ???
Im planning on making it very streetable and very track worthy with some low 11's in mind. Will 20psi max out the 50's? Phillip Long's Sy is a good example, but how much boost was he running? and Fuel pump(s)?
412 cam
SRP .030 pistons
Eagle rods
McCoy A2A
GT35R
RPM DP w/ minigate
ATR Headers
