TYRODD
My ass. Look at it.
Okay for those of you who dont have an Idea about what my truck is doing, it basically was all about the injectors-search for injectors and the first few threads will be mine :x .
I just got through putting the last three injectors in my Ty, hoping that it would fix my problem for good, but after 3 injectors @ $85 apiece, Im still in the same hole. It strange though, it felt like the same problem I've been having.
What may be a little different about this problem from the times B4, is that my truck starts up fine, Idles fine, zero flutter, basically perfect. But after about a minute, things hit the fan. I get really choppy idle, misses real good at ~1000-1500RPM. When my truck was missing B4 'cause of the injectors being poopy, it was having the same "miss" at the same RPM. But now it really just misses all the time, at all RPMs.
When I went out to test it out tonight, I got to about 65MPH, and didnt like it. It wasnt Knocking or anything like that, I just didnt want to make ANYTHING happen (some like to do this :wink: ).
Anyways,...My timing is fine, FP is fine, no codes, and AFAIK everthing else to my knowledge ::blahblah:: . I havent checked my wires beyond checking if they arc on anything, the engine compartment is about 80 zillion degrees right now, so I wont be doing anything tonight
Would the o2 sensor be doing this?, can it warm up enough in only 1.5 minutes to cause things to go awry?!! Can anyone give me some ideas? Ask me some questions!!!!
Time for more :drinking: , my car has hurt my feelings once again!!!! :evil:
TIA
-RJ
TIA
-RJ
