What is the biggest cam...
4C FED
Absolutum Dominium
that anyone has run, succesfully, w/ stock LB4 heads?
I know it's a stupid question, but I want to get this thing rollin' again.
I have McCoys', big valve, heavily ported heads (Stage 3's), but they are gonna require a major overhaul to make useable. :evil:
I have McCoys' big cam (special grind) and a set stock heads that only require valve guide seals.
Sooooo, I wanna try to put it back together like this until I get the McCoy heads repaired, correctly.
nick041881
the comp 422 is the largest one that i can find. i think anything bigger than that is going to have to be a custom grind. look on sites that have classifieds for old ASA stuff. alot of BIG cams for sale there. like .700 lift....too big if you ask me.
4C FED
Absolutum Dominium
Thanks, but the McCoy cam is like approx. .514 lift. I'm not looking to run a bigger cam.
I'm just wondering what kinda headaches am I inviting if I try to run the stock heads with this cam until I get the McCoy heads fixed.
E-Rue
im running the same cam on my L35's.
mark ran a comp 422 stokes grind on a stock set of L35's and it was stoopid fast.
as long as you can tune for it, i dont really think you will have any problems. you have a F.A.S.T. system right?
if your gonna fix the heads later, i wouldnt install the motor with a small cam. its too much trouble to remove it to reinstall the big one later with the motor in the truck. ive done it, and it was a PITA.
e
