What is this part?
hatrik8
So I was taking off my old brake booster hose to put on the RPM one. Then I slipped and broke off a plastic hose that goes to this piece. I highlighted it in red and it goes under the power brake hose. It looks like the EVRV Solenoid? What does that do and how much is it to fix? Expensive I'm guessing. :rotf:
hatrik8
Re: What is this part?
Actually it's #12 in the diagram. The part in front of the map sensor. The red tube is the part I broke off.
If I read you pic right it's the MAP sensor but it's only fitting is on the bottom so I'm thinking you really mean the other box which is the EGR control. Don't know the cost. EVRV=Electronic Vacuum Regulating Valve. Super Glue????
Flyin Ryan
hated cuz he drives fords
EGR solenoid.. just replace the hard vacuum lines to it with silicone ones or delete your egr system all together like me :)
I don't think they cost much new if you do need a new one.
hatrik8
I guess I'll try some super glue on the solenoid. The hose broke right off at the solenoid so I should be able to glue it. I have to get emissions testing done within the month so I have to get it fixed.
Flyin Ryan
I still have my egr solenoid and may even have the hard vac lines that run to it if you would want them.
hatrik8
I'll take you up on that if the super glue doesn't work. :tup:
Flyin Ryan
Well I hope the super glue holds up but if it doesn't just shoot me a pm it's chillin in a crate of all the parts i've deleted or replaced on the sy so it's not going any wheres
It just occurred to me, read the super glue package. Not sure it works on that kind of plastic. No harm in trying since it's already broke and you have a good option w/boosted.
hatrik8
Well I used plastic bond stuff. Same stuff I use to repair cladding and other plastic items. It seemed to work ok. I passed emissions better than last time, so I guess it worked.
Boostedpimp, do you have emissions in NJ? Are they strict? I wonder if I delete my egr if I'll fail emissions in CT.
