What is your Oil Pressure?
4C FED
Absolutum Dominium
Re: What is your Oil Pressure?
I switched to 20/50 when I did the oil cooler delete. I have 40 psi (with a mech. gauge) @ idle (running a 180 deg. stat) with the motor at operating temp.
James Thomas
"NO CLASS"
Well most of us know what "the book says" but I personaly won't have an engine in a daily driver that won't hold 15 + psi at idle hot and I like 20 ish psi (just me). At 2,500 rpm I like to see in the 50 psi range. I follow this rule other than a really loose built race only engine but that's not a daily driver now is it? For the "loose builds", I don't know if the 10 psi per 1000 rpm rule of thimb is dated or not but it has always been ok for me. I think your pressure is "ok" but still on the low side like you said.
Is the knock only at 1,200 and not higher? Does it really sound / seem to be rotating assy (crank / rods)?
__________
James
2fast4u
PUMPING THAT IRON!
I run Mobil1 extended life Synthetic oil(15w-50) with the extended life filter. My Oil pressure is 80 when cold, and 60 when warm. I have heard all the pro's and con's of running thicker oil. I have ran every single car i have owned with 15-20w 50 and never had a problem at all. IMHO, I would reccomend switching to a thicker oil and you will start seeing the good results Im having. 30 weight is as good as water when warmed up. Not good at all, especially with a turbo. When i first got my Ty, It had that initial 5 seconds of smoke when i first fired her up on the reccomended 30 weight. Since i've changed it to a thicker oil, never burnt a drop and all's good. Only problem.. If the bearings, and rings are worn from that thin watery oil, its really hard to bring her back to life.
SY2455
70's Veteran
I'm showing the following hot with a 160* stat. 35 psig at idle in gear, 45 psig at 1500 rpm, 65 psig going down the road. This is stock engine with 92,000 miles and Mobil 1 Synthetic oil(15w-50). I still change oil every 3,000. I went to the Mobil 1 Synthetic oil(15w-50) at 60,000 miles with no loss in performance and I change because during the hot summer months it seem like the oil press was low to me. Before changing oil the reading were 12 psig at idle in gear, 25 psig at 1500 rpm, 40 psig going down the road. At start up I show 85 psig cold.
ed hess
race or get outta the way
ok you have knock when warm
I have to tell you that even with 38 psi at 2000 rpm and haveing knock... the oil pressure doesnt mean a damn thing!
the motor has to come out.
I saw 2 spun bearings with 50 psi dead cold ambient and similar pressure when warm except for idle being closer to 20-25.
If you cut open your oile fileter you are going to see bearing material.
posting here hopeing for someone to tell you try this oil, try this filter etc in the hopes of it not being the worst case scenario is just wishful thinking.
fwiw you can expect to have the crank cut to salvage it if its not to badly damaged.
ed
60psi+ hot idle with Mobil1 5w-20 :)
Gotta love the moroso remote oil filter kit with 12an lines, b&m cooler and mobil1 302 filter.
I think it shows a huge restriction in the stock crap lines, filter and cooler.
Ty 1885
A knock just about 1200 rpm is why i got my TY so cheap $4,700 three years ago, it had a broken piston land.
The rest of TY was mint.
DaveP
This is long, Sorry. It's a follow up to all the good input that was posted overnight. Thanks. DP
Yes, and Yes. And only when warm. And not a 'connecting rod' knock. Not crankshaft speed. (slower). Seems to 'diminish' in intensity with the belt removed. Definitly near the front, bottom of the engine. Can almost 'feel' it by putting a hand on the intake manifold.
Here's some background: This was a stock used engine from a 92 parts car (wreck). 59,000 miles. Original Romulus engine, never apart. I dissassembeled, cleaned, checked, measured, new rings, bearings, head re-fresh, put back togeather. I didn't find anything alarming using the techniques I've been using for decades. It's had this noise since the beginning. Now about 9,800 miles, and I've beat the normal hell out of it, and it hasn't failed, or gotten worse.
I've built hundreds (literally!) of engines, and my experience has been that this thing should have blown up by now. I asked about oil pressure readings, because I have a hard time believing this is a ( impending failure) bearing noise.
When I went to straight 30W oil in my two L35 daily drivers, I liked the results. The engines SOUND better. A lot less 'rattles'. This change was prompted by rod bearings looking like shit at 100K. I haven't had an opportunity to look again since the viscosity change.
I agree. But it doesn't knock at 2000 RPM.
Again, I agree. I'd like to have an idea of what to look for. I don't know if it had this noise prior to my 'rebuilding' it, as I never drove it. I didn't find it the first time I had this thing apart, and honestly, I'm pretty good at this......
I've seen the same. Engines with spun bearings get worse and fail quickly if they are continued to be driven. This one hasn't.
I've done this twice. The first time was with about 2K of use. It had 'some' 'metal mud', but I think this was mostly ring/cyl wall from the honeing. The last time was with 4500 miles of use. Nothing. Clean. :dunno:
I agree something is wrong. If my pressures ARE lower than others under the same conditions, then I feel more confident that I will find 'something' in the bottom end upon disassembly/inspection. That was the idea behind my original post.
The responses indicating INCREASES in idle and cruise pressures with heavier oil viscosities are indeed interesting.
Than-You all for the input and responses.
Regards,
Dave P
DaveP
VERY interesting.
Was it Cyl #4, and was it visible from the top? I.e., could I see it with a boroscope?
Thanks,
Dave
sy445
I bought my sy on the cheap side because it had a knock. Broken piston and worn out main bearings. Of course I didnt know exactly what it was till i opened it up but it was all signs of detonation once apart. However, my oil pressure wasnt quite as low as yours. Worn out mains will give more clearance resulting in low oil pressure. You should cut open your filter and check for bearing material. Do you have a little bit of blowby? possibly from a broken piston?
twin74s
__________
James
LOL! my 2.3l in my ranger i sold only had 18-20 psi all the time... When it was cold it would make like 40 then just drop to 20ish. drove it that way for almost a year. 2.3l turbo's are invincible. Now to my Ty, warm its got 35 at idle in gear, and bout 60-65at 3k
