What issues should I expect to convert from a 4.3 to a v8
Skyhighsami
GMC Typhoon #1308
Given that I will be building a motor anyway I have really been thinking about swapping the Typhoon to a v8. I know that the 4.3 and 350 have alot in common. Other than the manifolds both intake and exhaust what other issues should I expect? Would fuel be an issue with a 225 in tank pump? What intake would be best? I was thinking something like the 350 Ram-Jet intake if that would work or is there something better? Anyone that has done this let me know what problems and issues come up. I would also plan for it to remain turbo. Thanks just kicking around the idea now weighing my options before I go very far into making it fast now and thinking man I should of.....
Re: What issues should I expect to convert from a 4.3 to a v8
Turbo V8 swaps aren't cheap. In addition to building/buy a SBC, Turbotime sell motor mounts, and for fuel injected intakes you have some reasonable priced options. That is the cheap part. You will really need a 4L80E and custom headers, Down Pipe, IC, fuel lines, bigger turbo, injectors, etc.
What are your performance goals and drivability expectations for your truck?
tbauer03
TRBOBOX
Prepare to take some heat from board members about converting a syty to a v8, keep it a v6 or go buy a s15 or jimmy
QWERTYphoon
Motley Driver Award 2009
:tup: I am with that guy, go buy a S-10.
Skyhighsami
GMC Typhoon #1308
Either way I go depending on how serious the motor is I was under the impression that I would have to go with an 80e anyway. I would like to run low 11s to high 10s. That is my goal if it runs a mid 11 I will be happy. No hard feelings guys I am just trying to deside what direction I want to take with the truck. A friend and I were talking today and he has a fast T Type and he said that he always wished that he had two more cylinders. That is what got me to thinking about taking the 4.3 out since it isn't the original motor so the truck is no longer numbers matching. So I am not sure how much that affected the value or collectablity of it.
SY2932
Administrator
It's YOUR truck, do what you want. I know that you will anyways
! As mentioned by dgoodhue, it won't be cheap to go V8. Be prepared to have lots of disposable income on hand to make it materialize. And if you decide to sell at some point, get about prolly 50% what you have into it...
Meh, there was a thread talking about the value of these trucks yesterday. The truth of the matter is that they will probably never be worth anything. If you bought a syty as an investment, boy was that ever a waste of good money
Windedv6
Ty n 10s
To run low 11s or high 10s you willl be maxing a stock converted 4 bolt block and stock crank. You can get there it just won't be dependable in the long run. To do a bowtie block and billet crank build the right way... figure $15k+, if you can even get the parts. You can make the same power in a v8 block cheaper and by not pushing it as hard it will be more dependable. The custom parts will cost you some extra, but headers, intake, etc are easier to come by for the V8 and not any more costly than for the v6. The issue is that you will have to track most everything down yourself vs the proven receipies of the syty board for the 4.3.
My advice is unless you want to go all out and spend a year and alot of dollars to only enjoy your Ty on the special occaisons (vs a more semi daily driver), do a typical proven build and enjoy driving your Ty.
treated stock crank
Eagle rods
JE/srp pistons
vortec heads
412 or 415 cam
stock style intake
50 or 75# injectors
upgraded fuel pump
Alky kit
GTQ67 or simular turbo
Waller 700r trans and converter
Phil Long, Waller or other good chip
New poly bushings and moog suspension rebuild parts
A rear sway bar and cal tracks
hydroboost kit.
Enjoy a wonderfull mid 11 sec truck that you can drive anywhere and at any time while saving your money.
I promise you that you will have a great time driving your truck, your resale value will be better for what you will have in it than a full out build that you will keep working on more than you will drive it. Also you will not need to spend 5k+ on a 4l80 trans setup as the 700r4 will be all you need.
If you want to chase the fastest on the board and go all out then you will need to spend twice as much as your ty is worth or more. Everyone will all congratulate you on you efforts and watch you spend your money. Someone will always come by and be faster no matter how fast you go. And the the biggy thing that you need to know is that most of us fast guys tune our trucks down on the street anyway. Our max times are custom bred for the strip. With pump gas and lower boost we are barely faster than anyone running the above reciept. We just are overbuilding everything to turn it up for the occaisional race day...usually just to see if we can beat an old record one more time and while hoping not to break again.
How do I know...because I got addicted to it and couldn't quit. Looking back I recall putting about 8k miles on my Ty the first year when I bought it new. I have since put about half that on in the last 13+ years.
Take it from me...these trucks are fun to drive. Spend $10K and have fun...or spend $30k and barely drive it. In the recent years, with the input and efforts of many on this board, we have come very far towards perfecting these trucks into a decently reliable, fantastic performing, 15 year old vehicle that still turns heads of most every car/truck enthustist. The receipe above is probably the most popular for the dollars spent because of reliablity vs performance. It gets a Sy in the tens and a Ty in the mid 11s. As the Larry the Cable Guy would say "now that's fast right there...I don't care what anyone says"!
Sorry for the rant everyone. I love my trucks, but I often wish I would have stopped years ago and just enjoy driving more.
John
Skyhighsami
GMC Typhoon #1308
That is the input I was wanting right there. Thanks.
NOJIMMY
treated stock crank
Eagle rods
JE/srp pistons
vortec heads
412 or 415 cam
stock style intake
50 or 75# injectors
upgraded fuel pump
Alky kit
hydroboost kit.
Take it from me...these trucks are fun to drive. Spend $10K and have fun...or spend $30k and barely drive it. In the recent years, with the input and efforts of many on this board, we have come very far towards perfecting these trucks into a decently reliable, fantactic performing, 15 year old vehicle that still turns heads of most every car/truck enthustist. The receipe above is probably the most popular for the dollars spent because of reliablity vs performance. It gets a Sy in the tens and a Ty in the mid 11s. As the Larry the Cable Guy would say "now that's fast right there...I don't care what anyone says"!
John
LISTEN to John.....he really knows what he`s talking about (owning two of the finest,
fastest Typhoons on this site, and also modding/owning a Syclone). Parts are a major concern nowdays
as exhaust manifolds, cast iron bowtie blocks, steel cranks, and such are rare (and
thus cost a fortune if located). No doubt you can go custom on some of these items
but then thats $$$$.
Not mentioned in many posts are the emissions/certiifcation testing (required by
lots of states)....the cost of race gas (so plan on alky, meth, or such to provide
detonation prevention)...suspension mods to handle the increase power....wheels
and tires (there are threads on this site listing the cost of larger tires) ....the breakage
of parts ....not to mention a good engine tuning/management system.
And SyTy vendors are far and few between (Ken Bell, ATR, and a bunch more
have gone bye-bye) due to low production numbers of these trucks. Magazines
(other than GMHTP) never cover these trucks due to their advertising sponsors revenue.
Sadly most vehicles listed for sale are partially modified (or broken) vehicles that
owners lost money, time, and expertise in finishing. A stock (or stock appearing)
vehicle will always have more buyer interest than an unproven, one-of-a-kind
SyTy (in my opinion), especially one with good documentation and low mileage.
But even these are not immune to price drops, as maintenance must be performed
or seals, corrosion, vacuum leaks, and rust will kill stored trucks as well (and
GM didnt do these trucks any favors with their painting process which fades rapidly).
Lastly, trends change dramatically in the hi-perf industry. While the 4L80 tranny, ball bearing
turbo, a2a IC, STUFF or FAST, and Disk Brakes from Corvettes (or Wilwood or Baer)
are now popular, 5 years ago members were experimenting with ultimate chip/3-bar,
shurflo pumps, blade-of-death IC scoup, fiberglass springs, and stock turbo porting
(my point is that these items were considered costly-state-of-the-art then and now
are bit normal/routine/cheap). Im sure E85 and some other technology will be "hot" in the
future (and thus make the current highly modded trend devalued as compared to
a lightly/stockish truck). So your high dollar parts become 50 cents on the dollar (if that).
We (as a group) used to draw 95+ trucks at SyTy events (in the old days). Now
were lucky to get 50 (and if you talk with the other 35 attendees without trucks, their "working"
on getting theirs to run as something is always broken, missing, or in-the-state-of repair).
Be prepared to buy a trailor (for insurance against being stranded).
Finally, a broken down "fast truck" by the roadside is a gift for thiefs/theft
(the cladding alone is worth 4-5K). If your not a car vendor (or business that can
write off the expenses) then simply enjoy your truck in a sensable affordable manor.
Or be prepared to join the ranks of the broke, frustrated, just-one-more-part,
sleep-on-the-couch (because you spent both your and her "play money") owner
of one-of-those-fast-corvette trucks (another myth of many that half the ignorant population
believes) that stays in the garage 60% of the time. Given the Big 3 are making
fast production model vehicles today....you`ll be hard pressed to be "competitive"
on the street with a 15 year old SyTy against supercharged, awd, twin-turbo`d trucks,
corvettes, mustangs, cameros, or chargers (not too mention $$$ for insurance,
court tickets, and the risk of vehicle seizure). The flip side is that NHRA is
always increasing their rules to maintain safety so to be competitive and race
means sacrificing interior room, comfort, driveability, and ease.
Again, others will disagree, but listen to John.
-Larry
Yep I had more fun with my truck when it was stock, since I started modding it heavily I have driven it less than 100 miles in 6 yrs.
denny
treated stock crank
Eagle rods
JE/srp pistons
vortec heads
412 or 415 cam
stock style intake
50 or 75# injectors
upgraded fuel pump
Alky kit
hydroboost kit.
John
Well said!
Napper
I'd think it would be easy.
a Lt1 would bolt up to the 700r....isn't that the tranny used an Awd tranny from the Safari
they sell them complete with computer..... the engine parts would be cheap, and custom headers are no big issue.. people pay 1200 dollars for headers premade...custom are far less.
tranny control would be the issue...i'd think a masaged LT1 could put out well over 400 whp..
combined with awd and the low end grunt of the Lt1...make a stroker....
i was thinking about this...the Sy tranny is an Awd 700R they call it by another name but i read it in a gmhpm.
if you could work out the electronics ......no its not an electronic controlled.....or pcm..
all i know is with the right parts there are shops that can convert anything...dropping a v8 into a sy awd sounds killer. monster torque.....no need for real top end so spining the motor to 6000 rpm is fine. Perfect 1/4 mile combo.
but i'm a noob......i do know my sbc ,Lt1 and LSx engines
Yep and once you get the lt1 installed it will be slower and get less MPG. Great mod.
And before you claim I don't know shit, I do own a v8 typhoon. And by far it was not a cheap mod and I already had the engine. Most of the time I wish I left my truck stock and just drove the thing.
Aeroking
e.i.
x2 You gonna spend money on a 280hp 300ft/lbs LT1 conversion, as opposed keeping the stock 280hp 400ft/lbs... doesnt make much sense.
lol, my LT1 T/A was slow as balls compared to my LS1 T/A, and off the line niether could hold a candle to a SyTy.
but Its your truck, your money. Good luck.
SyTy make more torque stock than most NA LT1's (even modified ones). 420-440ft-lbs stock, 500ft lbs with just a chip. Torque and traction is the key to what make these truck stop light warriors. It's also why they eat 700r4. I supose a NA LT1 stroker would be easier on the transmission.
UR50SLO
V6+2=LSXCamaro
John.. (Winded V6) That was the most thought out well writen posts about advice on modding one of our trucks I've Ever seen.
Well said!
~Scott
Syclones rock
I'd keep the 4.3 .to go 11s , Its probibly cheaper to mod the engine you have now then to do a v8 conversion .....just my :2cents: .
supersports10
treated stock crank
Eagle rods
JE/srp pistons
vortec heads
412 or 415 cam
stock style intake
50 or 75# injectors
upgraded fuel pump
Alky kit
hydroboost kit.
John
-Larry
these are the best posts that i have ever run across!!!!
i personally agree with tham and want to go as fast as possible, using the cheapest, off the shelf, and stock parts that i can.
tookycat is the person that i think best personifies this philosophy:tup:
