What muffler...or none
wantingasy
I've been searching through old topics about exhausts and now that I've passed smog I want to change it up a little bit. I was considering just taking off the muffler all together, but I do have to pass smog in another 2 years. Right now I have the ATR exhaust, but want something louder. I was looking at either the magnaflow round muffler or borla. How do these compare sound wise with no muffler? I'm so tempted to just take the muffler off completely!!!
gjp
another post whore
Re: What muffler...or none
I thought flowmasters were not good for our trucks?
jjorgensen52
NHSTE - I'm the only one!
most vehicles I've ever heard without mufflers but with exhaust sound like crud... :2cents:
Well i have a flowmaster 40 series dumped before the axle and 3in pipe from the cat-back and it sounds pretty decent, but from my experience go with the Dynomax ultraflow welded mufller it sounds much better on the V6 than any flowmaster. and they are cheaper.
If your interested i have 2 brand new dynomax ultraflows still in the box i bought several years ago for a 2001 blazer x that i never got the chance to install them, they are center in and out and 2.5 in and out make me an offer if your interested?
Flyin Ryan
hated cuz he drives fords
Flowmasters tend to not flow as much as others but each truck is different soo.. anyway Im using a 3inch dynomax ultra flow and like it alot.. not too loud and has good tone
attackdog
I went with no muffler and it sounded sweet. It can get a little loud at times but I could hear the tubo alot better. Make sure you keep the cat. I tried removing that also and ran into boost problems.
ghettosled
SYTY SUPERSTORE
well every truck i have ever worked on with a clogged or bad cat converter ALL had flowmaster mullfers.. Each and every one of them.. I sense a pattern :)
Personally i recommend straight through 3" in/out.. Dynomax, Magnaflow, Borla, etc.. With a turbo motor you want the least amount of backpressure possible..
SY2455
70's Veteran
If you want. Listen to these, and tell me what you think. I have no problem with smog inspection.
http://www.350ci.com/syclone
TYTILIDIE
METH HEAD
I say no muff. I had my exh built by a local guy. We put 3" CAT and out the back and I think it sounds bad ass. I actually get compliments that it sounds mean. It really isnt too loud with no muff IMO.
Well if anybody remembers way back when these trucks were built, GMC's origianl idea was to not hve a muffler from the factory, because the turbo and the cat provided enough sound deading. But the emmisions people got involved and said it had to have a muffler.
MRKING
New Parts for Old Trucks
Thats the same as on my sy . I cant wait to hear the new turbo setup through it , and i hope it isnt to loud .
HotRudyRod
I have what i believe to be the stock muffler, its called some like bulldog or pitbull and a exhaust valve right after the cat and no filter or anything on the turbo and when i open the valve the turbo's sound is just badass! It sounds LOUD and the wastegates flaps are fun too, then i just pull up the lever thats instaled behind the passenger seat and voila! no noise at all. The muffler sounds good at WOT but nowhere near the valve.
SY2455
70's Veteran
It was the noise people within GM that made them put mufflers on, so they could bring down the drive-by noise 10db.
ZavzTy547
Senior Member
QUICK STORM said:
can't view the videos
I have a 3" cat and no muffler and its nice and mellow at idle but it can get pretty loud when your driving and will get annoying after awhile, If I'm in a parking garage, it will always set off someones alarm.
