Bad Ass Black Trucks
I picked up a used, high mile syty long block to throw in the Ty while I sort out issues building my motor. Got tired of not having the Ty on the road and I kept having setbacks with the build.
The leakdown test was good on the old motor so I'm moving forward with it. I also figure that having a stock motor will allow me to get the tune dialed in as I do upgrades. I was a little concerned that jumping straight to the built motor with a cam and ported L35's would put me out in left field as far as the tune goes and I was concerned that I wouldn't be able to get it sorted out. If I get some miles and tuning experience out of this motor I'll be happy.
So, to my question. I have several things I can do or put on this motor, but don't know if I should go ahead or hold off.
-I didn't think the leak down test was bad for the mileage, ~15-25%. I didn't notice anything getting by the valves or coolant passages. Seemed to just be going by the rings. I do have a full set of valve seals and the tools to do the job. Should I install them while I have easy access or not worry about it? The motor had around 115k on it.
-I have a 60-1 turbo, 3" ATR Downpipe and external wastegate. I want to go ahead and install them rather than deal with the hassle of removing the stock turbo and downpipe later. Bad idea? I plan to keep boost low initially and have a 2800 stall tc for the transmission.
-Should I start with stock injectors or drop in 62 lb injectors I have?
-I have a greddy boost controller. Should I wait to hook it up so the ECM can control boost?
Anything else I should do while the motor is out? I plan to insulate the purple wire. Already have solid motor mounts.
