NJSERRANO
I have a 65k mi Syclone. At or around 3k rpm, I hear a little pinging/detonation. (I let off immediately). I think it has a Kenne Bell chip. The car sat for several years before I purchased it. I'm in the process of getting a 255lph pump and racetronix hot wire kit.
The stock injectors are on the car. Should I upgrade to NEW/larger injectors?
If so, what size?
Thanks!
Mods include:
Kenne Bell Cold Air Kit
High Flow Cat
Borla Cat Back
Kenne Bell AFPR
NEW tune up includes:
NGK ur6ix
Bosch o2 sensor
MSD Coil
Accel Cap/Rotor
Kenne Bell wires
PCV valve
RPM egr delete
fuel filter
new radiator
160 t-stat
If so, what size?
Thanks!
Mods include:
High Flow Cat
Borla Cat Back
Kenne Bell AFPR
NGK ur6ix
Bosch o2 sensor
MSD Coil
Accel Cap/Rotor
Kenne Bell wires
PCV valve
RPM egr delete
fuel filter
new radiator
160 t-stat
