what size is the o2 sensor...
SeattleSy#1255
Category 5 Conservative
i can't get this thing out...even vise grips slip off...i don't have anything larger than a 17mm so before I buy something I'm looking to get the right size.
any advice on this POS.?
sytyguy
Moderated User
7/8" - A lot of companies make a special socket with the slit in the side for the wires to ride in. Makes it easier to get it off without rounding off the sensor. Lisle PN is 12100.....available @ any major tool supplier (Sear's, Harbor Freight, etc.....).
Soak the sensor in PB Blaster or run engine to warm up sensor. Either method should help you break it loose.
HTHs
Hood
Loeryder
if your O2 sockets starts to open up put a hose clamp around it to hold it tight against the sensor.
I've also cut the wire, beat the heck out of it and put a deepwell full wall socket over it.
PB Blaster is your friend.
SY2455
70's Veteran
I'd had to cut the wire & use my 1/2" drive inpact gun with a normal 7/8" inpact socket & this was with the engine at operating temp. but I must say it had never been changed before & truck had 61,000 miles. This was after I bent a Lisle socket to the point where a hose clamp won't help. I just used a 1/2" ratchet on it. The guy I got the truck from said he had just changed it at 50,000 miles, along with a so called complete tune-up, but we've all heard that before with these trucks right?
