Re: What Spark plugs do you use...
reason I ask is im getting a ton (20 deg. no alky on pump gas) of spark retard and trying to figure it out I pulled the plugs and they look fine.
im running 20psi (bad I know) im turnning it down now to 15psi to see if that helps I dont want to put on the alky before I get it running tighter and im guessing if I turn the boost down it might be faster because less knock? and if I get less knock then I put the alky on it should help out that much more?
what is the stock rev because im getting 4900 rpms in a WOT run
also are the shift points done by the chip or because I have some trans stuff done like a shift kit and boost valve will that change it to do different shifts... and allow it to rev higher I dont want it to over rev and blow up so do I get a MSD rev limeter or something like that.. or have the chip reburnt...
1 more thing E-RUE and PHIL are very smart with these trucks thanks for all the help so far im sure there will be more :tup:
