Maverick87
I have been having kr problems so I have done the following things.
new plugs(ur6ix gaped to .032)
new cap & rotor (conrad)
plugwires(taylors spiro pros)
o2 sensor
map sensor
tps
new pcv with the E on the bottom
knock sensor(relocated to the hole in front by the thermostat)(torqued to 14ftlbs)
iat sensor
my ia temps are in the 60-70 o2 volts 920-950
fp raises with the boost I am only running 14-15 psi
Iam still getting kr . Somtimes it is 2-3deg and sometimes it is 7-10deg I have checked to see if anything is rubbing nothing there.
What have I missed?The kr didnt change when I moved the knock sensor. and if I run 100 octane the knock goes down but not away.
Somebody please HELP
Thanks mav
o2 sensor
map sensor
tps
iat sensor
Thanks mav
