What to do with free dyno time
Ian Turgeon
Cascading Inspiration
I entered myself in a little contest on a local board, made a few web bannar designs, and won myself an hour of free dyno time w/ wb 02 and "tuning services".
Now my question is what to do with this time? I'm definately putting my truck on the rollers, but should I take this time to figure out what different boost levels equate to? Should I try things like see how much power I get with x intake? maybe how much power I get with x exhaust?
my current setup:
stock turbo, aux hayden, jabsco, walbro, kb afpr, innovative external, exhaust dump at saudi res.
What do you guys think, what are we interested in seeing number changes for?
sytyguy
Moderated User
I would like to see the difference in intake setups. I know that some have gotten no gain from removing the intake at the track, but with so many variables there, it's debatable. Just a simple 2 run test would suffice for me.....stock intake on one, open to turbo on the other. This would settle the debate (at least in my mind) for stock turbo/engine/etc....trucks.
I would personally like to see (on my truck) the difference in open dump and muffler'd setup. I have a fairly restrictive muffler on mine so the difference would be very obvious, but it'd be cool to see it with the Saudi resonator as well.
There are other tests I'd love to see done, but with your combo I think those 2 would be most interesting.
I will be able to do some of this on my own when I finally get my own chassis dyno (the day is coming soon). My truck will probably never get off the lift when that happens though. :wink:
Hood
SeattleSy#1255
Category 5 Conservative
Mike, this was done a few years back over here...running an open stock turbo (delted intake crap) we gained 15hp. Just thought i'd throw that in.
sytyguy
Moderated User
15hp.....cool. Never knew that Jeff.
Wouldn't happen to have a dyno sheet on those 2 runs would you? Would like to see exactly where in the power curve the extra air was beneficial to the engine.
Michael
Ian Turgeon
I'm definately going to do some boost level runs.
probly.
15psi
17psi
I'd like to try the intake stuff as well, stock, stock & K&N, stock with cone filter, open intake
Maybe try something like iced IC temps vs hot IC temps
Maybe I'll buy one of those throttle body splitters :D and prove that its a waste of money for us.
Ian Turgeon
Actually I just remembered my modified stock turbo will be done by this time. I'd actually like to get numbers on if the housing port work made a difference.
Since mike is working on getting his own dyno, maybe I should dedicate the time to testing the modified turbo housings vs stock. Once he has that thing, im sure he'll be doing runs constantly testing everything he can think of.
sytyfreak
What about those little aire filters which can be mounted in the mouth of the turbo??? I remember seeing some pictures of a SY ot TY using it, but that topic concluded that it had more cons than pros... Can someone refresh this up???
sytyguy
Moderated User
No doubt......I plan to dyno everything different about our trucks that you can imagine(air filters, iced intake, boost levels, etc....). That'll be the easy part. Paying for the dyno, however,........... :D
Hood
TurboManiacal
Michael
There was an extensive post written up by the seattle guys on this..Jeff Norman, Richard Lee, Jeff Proudlock, Scott (now of Dearborn, Mich) and others that did a great writeup. Of course, I'm too lazy to look for that e-mail on the list archives.
Loeryder
I'd go have a contest on who puts down the most HP on their razor.
Another idea would be to manually advance/retard your distributor until you get the optimal HP.
But yeah it'd be cool just to get some runs in for reference.
Maybe split a couple runs between 2 trucks.
I bet you can get em on and off in under an hour.
Ian Turgeon
I think im going to end up doing just some tuning stuff, and getting boost level differences.
Got bg's 22# .bin, im gonna see what some race gas, some extra boost, and timing/fp can net me. I will do the baseline w/intake and w/o. And will probly end up running the rest of the pulls w/o the intake if it truely does net a good 15hp.
Ian Turgeon
canadian said:
i'd just like to see the run. where are you doing it at?
as listed on the addy below:
attachment.php
I'll send out an email to the fast people when I figure out date/time stuff. I wanna wait till my ported turbo is on, which is taking it's sweet time.
