What to do with stock o2?
TYTILIDIE
METH HEAD
I get my wide band tomorrow and am wondering what do I do with my stock 02. Do I still use it or do I toss it? What happens ECM wise if I get ird of it? Also, where are most people putting thier bungs for the WB. Thanks in advance.
cloneman315
Re: What to do with stock o2?
if u are running open loop u dont have to use the stocker,if your not then depending on the wbo2 u can use that sensor for your wbo2 and the ecm
TYTILIDIE
METH HEAD
I dont understand what you are saying. Im getting the LC-1 I believe. When you say THAT sensor, you mean the stock or the WB? Can I ditch hte stocker and run closed with the LC-1?
Quickstop [UK]
Combating adversyty.
yes - you can ditch the stocker and run closed loop with the LC-1. You will need to run a lead from the LC-1 to simulate the narrowband and configure it but you can do it. The manual explains it.
Just put your new LC-1 sensor in the same place as the old sensor. If it works you may as well keep it - never know when/if you will have probs with the wideband.
Juat read your sig - can't believe you got that far without a WB O2!! Nice work!
ashman
the LC-1 comes preprogrammed to simulate narrowband on channel 1 (ie..no changes needed). channel 2 will need to be programmed for WB. there's a post by skywayb (Paul) that illustrates how to program the 2nd channel for our trucks.
TYTILIDIE
METH HEAD
I see. Well I guess Ill get it all hooked up and then start asking questions. I m supposed to get it today, UPS usually come saround 5 and its only 12. I cant wait, hopefully I get my tranny working goog so I can start my tunign adventure.
