What to look for in Datamaster
SeattleSy#1255
Category 5 Conservative
Looking for some help. Just got datamaster and went out to make 3 quartermile runs. Now, what do i need to be looking for in these recorded files. Knock, seems to be the biggie but, what is the difference between knock count and spark retard? What are good numbers and bad numbers at WOT? What else should i be looking at?
Thanks in advance!
Falco
0* spark retard is the best. If you have knock the ECM will retard timing. However the algorithm it's using is still blur for me.
Some other things to look for at WOT.
Engine temps, -depend on you thermostat, with 160* at the end of an 1/4th run i usualy see no more than ~170*
Intake temps, -20-40* more than ambient
Battery Voltage, - ~13.4V is good
TPS, -100%
O2, -in the 920-950mV range
Boost against target Boost, -no spikes, no lazy boost
shift points, -1st-2nd ~4300, others ~4500
If you search the BB you can find some good post on Inj DC and BPW too.
HTH,
