What turbo for Vortec heads?
jjorgensen52
NHSTE - I'm the only one!
Alright... I'm upgrading my motor to vortec heads and getting the intake ported to match... any recommendations for a good turbo/injector combo, for say 350 horse? Running stock cam at the moment... might upgrade that too. Any info would be good...
jjorgensen52
PPI Typhoon said:
If you just want 350hp, you can do that with the stock turbo......
Stock turbo's on it's way out... 160k miles on it. Will the stocker have more lag with the new heads?
PPI Typhoon
DIY Madman
I'd check out this spreadsheet that Brian Green did. It can help you with the combinations.
http://www.syty.net/phpBB2/viewtopic.php?t=25006
As far as the turbo lag, that I'm probably going to have to figure out on my own, as I'm going to be doing the heads/cam upgrade myself in the near future.
But you may want to also look into the 20g upgrade route. I've not done this myself, but there are many posts about it on here.
jwaller
Evil Genius/SyTy Guru
with a set of vortec heads you can run any turbo you want.
but if your goin to drive it on the street a good bit then stay with something small. 20g upgrade or pte 52 or something. this way it will still drive around and feel quicker on the street.
if your goin to go with the 52 route try and get it in a BB configuration then you might not need to swap converters too.
jjorgensen52
I'm gonna be on the street a bit... according to the spreadsheet PPI Typhoon mentioned the 20g can go with the stock injectors... there won't be any fuel delivery trouble there? I think the 20g is what I'm gonna use.
93ty475
are you going to freshen the engine up or just upgrade with these boltons? if your pulling the body, the motor would be most accessable to freshen it at the very least... check out this page for further info http://syty.huryde.com/html/engine/build_specs.htm
good luck,
jjorgensen52
I think I'm gonna need the luck... the motors gonna get freshened up, new bearings gaskets etc... probably new psitons and connecting rods as well. It's already out of the truck (in case you can't tell this thing is in about 500 peices... :wink: ) Anyway I have pics of what i've done so far @ www.typhoon1357.50megs.com (the photo pages are in order so page 4 has the most recent pics)
Thanks for the info,
AXXE
I run a GT35R dual BB on a motor with Vortecs and a 412 cam with #50 injectors and a Waller chip with the stock converter. It has no lag.
smeagol
It's all going to depend on your goals & budget.
If you only want faster than stock, and are doing Vortecs... do a 412 cam, with maybe a 20g, or a PTE based 44 or 51. If you want a bit more out of it, go with a 52 or a bit bigger, maybe consider a different cam etc. The spreadsheet i made up was to help with these kind of decisions. You shouldn't build a motor with Vortecs and a mild cam and then use stock injectors & stock turbo. You shouldn't build a stock rebuild and use a 72 series turbo with a 422 cam. The best bet is to print out that spreadsheet, and pick parts right around the same vertical line drawn on the paper. Considering you don't want to do anything too radical, or out of the norm here, look at what others on the site have done.
nightdiver
This is the combo you want with NO LAG
ed hess
race or get outta the way
just out of curiosity here,
1 who did the determination that the gt35r is the way to go and not the gt40r?
2 what does the gt35r compare to in terms of lets say the pte lineup?
3 what does the gt40r compare to in terms of the pte lineup
is this because right now you can get deilvery on a 35 but the 40 has a longer wait?
ed
nightdiver
This is a good combo for the stock tc.
There are many combinations to follow but i think that he doesnt want too much hp. The gt35 is the super 60 with BB good gor up to 550-600 hp , right ?
If you ask me i would use a T67 P trim with an external and a .70 or .82 turbine. Also a 2600 stall would keep it in the boost area....what do you think ?
ed hess
i dont know thats why i am asking!
ed
E-Rue
ed
1. its a great turbo to use if your looking something slightly larger than a PT52 with the spoolup of something smaller.
2. its a good comparison to use the PT61 against the GT35R since they share compressor wheels.
3. the GT40R is a little more tricky. its brand new, and PTE doesnt have any yet. it would be comparible to a PT67 as far as i know. and would be a REALLY hot turbo for a mildly built truck. its really the missing piece of the puzzle in the garrett line because the GT42R is such a jump up from the GT35R. its still unclear to me as to weather it will fit in a PTE syty turbine housing or not. again PTE doesnt want to talk about it till they get some of them in stock. cross your fingers garrett starts shipping them soon. i predict its gonna be the hottest turbo yet if it will work for us.
e
nightdiver
The T67 is the turbo i really like. It spooled with no lag and would give a lot of torque too. My stall speed is 3000 rpm (T78) and it stays there with boost against brakes at 3 psi.
The extra torque of the T67 could rape my 900$ 9/11 TC to 3500 with a .84 turbine.
Things like that makes me want to built a torque monster than a max HP engine
jjorgensen52
sounds like the gt35r is the way to go... Garrett's catalog claims it supports 300 - 500 horse, so it sounds like it would spool up quickly here... thanks for all the info...
AXXE
I don't know where Garrett get those HP numbers from. This turbo makes a lot of power fast. Precision has the PT61 listed for 680 HP, and I dont think that has the GT turbine wheel on it. My truck is faster with 10 psi than it was with my stock setup at 18 psi. It feel's good with the stock TC, but I need to get to the track to see the 60ft times. I think with a stall a little higher than stock, it will be amazing. I was actually suprised how well it worked with the stock TC. I like being able to still feel my truck shift, not like trucks with loose 9/11s in them.
If that GT40 comes in the larger 4 inch compressor housing, it will be a bitch to fit in. The best bet would be to use a spacer on the exhaust manifold and bend the downpipe to fit or get a custom DP. My turbo almost hits the AC compressor and it's the 3 inch inlet. I am sure by the time it is available, they will have something figured out.
E-Rue
garrett rates their turbos very conservatively compared to PTE. by the way PTE rates their stuff you could say the GT35R is capable of much more than 500. for example PTE rates their 61 at 680hp and it uses the same compressor wheel..... also keep in mind the peek hp ratings of any of these turbos are unrealistic with our motors. big torque less hp.
e
ed hess
>>>If that GT40 comes in the larger 4 inch compressor housing, it will be a bitch to fit in. The best bet would be to use a spacer on the exhaust manifold and bend the downpipe to fit or get a custom DP<<<
:D :D :D :D
ed
