Re: What Turbo?
QUICK STORM said:
hmm.....
i see he has a stealth70 but what is the gtq option?
last i knew gt series garrett turbo's were water cooled then the q would be the trim style/option
"2) Lots of people like the p-trim exhaust wheel for some reason. It's
> mainstream, everybody gets it..... at least that's why I got it on my 1st
> single turbo...... It's a good wheel and support good power... but in my
> experience, the q-trim wheel has a better "power to spool" ratio than the
> p.... (the nomenclature is simple, later letter in the alphabet = bigger
> turbine wheel). I originally just wanted a q-trim wheel.... the "gtq"
> thing is explained later in this post..... but anyways, if you want to make
> BIG power (660+) through a p-trim wheel, you need to upgrade to a .81+AR
> exhaust housing, which hurts spool by ~500RPMs..... or you could do what I
> did, upgrade to a q-trim exhaust wheel and keep the small .68ar....
> > and only lose ~200rpms of spool, yet have the ability to make about the
> same power as the p-.81 combo......"
see this pic.. it shows , from left to right, a P, a Q, and GTQ
just a little something i found on a supra site that might help a little
