what valve springs?
Tyrant
i was just wondering what valve springs to use on L35 heads.........should i use the factory ones or go with something like an LT1 like i have heard some people try???
thanx in advance
myclone
what cam are you using?
If its below .500 lift the comp "conical" springs will be fine to just above 8k RPM and no machining work needed. They drop in. Gotta use their retainers though.
Falco
Are you sure they can clear the rocker arms?
Jake, As far as the cam. I thought that the 422 is a bit too much for the L35's. I could be wrong. Will the heads be ported? What about with the 412 cam? Or the Crane HR-204/286?
Later,
myclone
I know the conicals clear the comp cams roller tip rockers (which I dont like BTW) just fine.
IMO it depends on the type rocker if it will clear or not. Most aftermarkets would Im sure. Dunno bout the stock rockers do to pitching them in the trash when I do a build thats more than mild. I doubt the stockers would clear the retainer but youd prolly run out of slot for the stud first with that lift.
