whats a good fuel pressure
doomdead
im running stock fuel pump at about 40 psi for the fuel pressure, when i put in the walbro pump, what can i turn the pressure up to? or do i need to even.
Stock FP with the original Bosch 237 FPR is 45 psi with the vacuum line disconnected. I've run over 50 psi on the stock chip with decent track results. I would recommend at least 48 psi base FP with a stock memcal. This is all irregardless of what fuel pump is in your tank. HTH,
