What's a good WBO2 sensor
AlaskaTy
My O2 is trashed and my truck is going to be down for a while so I figured I might as well get something cool with my tax return. I don't know much about wide band and was hoping I could tap into the brain trust on syty.net. I have a problem with always buying really nice stuff for my truck so when I saw (forgot the name) one of the latest wideband kits (datalogging, display, etc.) it peaked my curiosity. So I was wondering two things:
1. What's a good beginner kit w/display?
2. What's a really good kit?
I'm putting my price ceiling around $500 (+/- of course) if I decide to go for a good one.
I'm thinking about ordering ASAP so I can get that in my truck when I get time to pull the injectors and whatnot. Thanks.
2kwik4u
Resident slow guy
Re: What's a good WBO2 sensor
If you are logging via the ECM than I have to say that the LC-1 (I think thats right) that JSM uses is VERY nice. Plugs into the cigarette lighter, has a nice little LED that lets you know it's working, and has a small module that you can hide in the dash fairly easily. Seems to work like a champ as well.
If you need a gauge then I'm lost, as I've never used one with a guage...sorry.
I added the cig. lighter to make it easier to move around.
You can buy an external gauge for LC1 also. Just watch that you don't short any wires out.
SBNova
Ive got a Zeitronix. It doesnt come standard with a display, but you cant really read a display when you drive anyway. I use an old laptop to display and log my runs. Its much easier to see on a 12" screen than any gauge or mini-display. The Zeitronix doesnt need anything extra to log other parameters (up to 5) except the sensors themselves.
If you get a wideband, you usually would not permanently mount it, nor will it replace your stock narrow band (although most have an output to do so if you want). I use mine with a tailpipe adapter that I made to fit on all my cars. I just hooked mine up to the Ty today (13.xx at WOT- got some issues!) but Ive used it ALOT on my carb'd cars to get them running great with good mileage too. You cant or at least shouldnt run the engine without the WB powered up, so forget leaving it in the tailpipe/exhaust stream when your not using it. Any hole you make for it can be plugged with a spare 18mm thread spark plug.
AlaskaTy
Can I datalog with datamaster with the LC-1? Can it replace my narrow band O2 or do I need to get an additional bung welded up?
SBNova, are you saying I shouldn't have the wbO2 as my only O2 sensor?
MRKING
New Parts for Old Trucks
I have the Lm-1 , same as the Lc-1 but with more stuff . The analog gauge is a good option from them and both ran me little over 3 bills .
AlaskaTy
Do you find the gauge handy? I just figure that when I'm datalogging I'll have the values...plus my 3 pillar pod is full.
gjp
another post whore
I could use that info too.
leroy
The widebands need an ecm code patch to read it in datamaster. I've used the Innovate, PLX, and diy-wb. It's hard to beat the LC-1 for price right now.
You can run just the wideband without the original sensor. I would recommend an open loop chip if you do this. Most of the widebands have a narrowband output, if you have to run closed loop.
Jason, I think a lot of your problems could be solved with a wideband and a couple of hours of tuning.
Jim
Jim
Did somebody say TUNING????????????????????????????
SBNova
You can run the WB in place of the NB on my Zeitronix using the NB output. Is it as good? Who knows. Its a converted signal. Do you really want to wear out your WB sensor using it everyday? Id rather wear out a cheaper NB sensor. Some WB's use a very expensive sensor. Mine is avail for like $50 so it not that big of a deal.
My opinion is- a wide band is a tool. Its not like the gas gauge or the tach where you can do something about a problem. Once tuned, your truckk should run consistently enough to (practically) never need to look at it again. While tuning you'll need to check it frequently. After tuning there is nothing you can do from the drivers seat to alter the AF ratio.
Also, like I said before, *most* displays are too hard to read to bother having. Ive got mine displaying on an old 11 inch screen/ laptop. When I am driving I can barley keep track of it. Datalogging is the only real way to do it. Your not gonna go for a blast and remember the ratio at a certain RPM to fix it.
MRKING
Well I see what you mean but I cant say I agree completely . I am going to say "most" of the more powerful trucks arent daily drivers so the wb isnt even getting used daily . On a low 13 high 12 sec truck yeah you might not be as worried about it , but on a mid 11 sec truck and lower , you have to look at things a little closer *ALL* the time . On my LM-1 the display is big and bulky but easy to read , and in case I have the larger box tucked away out of view , I have the analog gauge as well in my pillar . I have my ostrich emulating full time and I really dont plan to go back to chips because a tune is never perfect all day long , outside temps change , humidty changes and that plays a factor in how your truck runs. So really "I DO" go for a blast and then pull over to make changes . I am deffinately still learning but I demand peak performance from my sy all the time , and I always want to know what she is doing . Its all comes down to how you use your truck and what your goals are .
