What's that knock
Matthew Little
Truck has a knock around 1600-2000 rpms. Just under normal driving I get 1-15 deg of knock retard, but under 1/2 to wot no knock at all. I can hear when going slow up to my house,sounds like a lifter tick,but I have already checked ajustment. Any ideas?
Thanks, Matthew 92 ty
kwick6
Re: What's that knock
what chip and injectors?
Matthew Little
knock
knock
I have an atr pitbull street for 40's. The 40's were in the truck when I got it ,and some people I have talked to on the board said the would not be big enoungh, but I am running a 20g and can not get the truck leaned out. I am planning on going back to stocks, but did not get them when I got the truck.
93ty475
Re: knock
Re: knock
my truck came with the same setup...are you sure they're 40 lb injectors? i think mine had a red stripe...someone said they dont work well on these trucks...i dont think its a "not big enough" issue...mine ran like #@$@# until i put some stockers back in and a stock chip....ran MUCH better then...
servando
kwick6
Re: knock
Re: knock
Then I have no idea what the problem could be, sorry.
Matthew Little
knock
knock
Thanks anyway kwick6,It's not running like sh## but not up to what it should be,The thing went 8.60 with a dead intercooler pump, vac leaks out the as# and a bad coil,the 40's were put in shortly before I got it with a kb chip which I quickly took out, The gm book calls the sound an off square valve or spring,I wanted to put rollers on it so I haven't taken it apart yet.
